Park Assist PLA 1.5
Park Assist PLA 1.5
Finally instaled on my Jetta MK6!
1. If you have factory PDC OPS system you need this upgrade kitt: http://www.carsystems.pl/vw-golf-mk6-5k ... id649.html
2. If the car doesn't have PDC OPS system from factory, you have to buy this kitt:
http://www.carsystems.pl/vw-golf-mk6-5k ... id665.html
My car have PDC OPS from factory.
The PLA 1.5 upgrade kitt contains:
- 2 x PLA sensors 1T0 9191 297A
- 2 x ring seal 1T0919133B
- 2 x PLA sensor holders (on carsystems seems they are from Touran - I used from CC 2012+ : 3C8 919 399 and 3C8 919 400)
- 1 X Park Assist button 1K0927123B REH
- 1 x PLA 1.5 unit 1T0919475P
- additional cables
On the bumpers, the SELF PARKING sensor position is provided during production. Drill 28-29mm holes for PLA holder sensors. They are fixed with adhesive tape wich is provided. This is the easy part. Changing the old PDC unit with the new Park Assist unit was very hard and very difficult. It took me about 2h.
The unit is located under the dashboard in the right of left wiper. Space acces is very limited.
The connections are similar with Golf 6. In the end:
a. Go to adress 44 Steering Assist - Adaptation - Installation Park Assist and change value from 2 to 1 b. Go to adress 10 Park/Steer Assist. I choose Golf Plus (Jetta doesn't appear as an option) [youtube]http://www.youtube.com/watch?v=EG9R9mME7eQ[/youtube]
- additional cables
Re: Park Assist PLA 1.5
Why did you used different PLA sensor holders then the provided ones from carsystems?
does the delivered ones fit too?
Thanks
Thanks
1,4 TSI Hybrid Highline
Because at this time carsystems sent me PDC sensors and brackets instead PLA sensors and brackets.
Now carsystems provide correct sensors and brackets.
Thanks Hayate, just received the upgrade kit from carsystems.
I am going to install it on Sunday.
Everything looks fine!
I cant find the PDC unit.
Searched for hours with no result, only found 7n0907530ah and 5k0937086m.
I also removed the wipers and to get a better view.
Maybe the hybrid has an different location for the pdc unit?
After you will remov the wipers you will see a plastic cap.
Unscrew and behind you will see a small hole. To remove the PDC unit you need to rotate the PDC unit to the left.
I forgot to say that you need to remove the speedometer:
Zuletzt geändert von Hayate am Montag 20. April 2015, 15:45, insgesamt 1-mal geändert.
thanks Hayate.
It's finally working now.
I had to remove the tachometer to see the pdc unit.
Hi Hayate,
did you already upgraded to PLA 2.0?
Ive everything here to upgrade my System, but iam not sure if i only have to add the two new cables from rear PLA or if i also have to change positions of the old cables on the PLA 2.0 Unit.
thanks
thanks
Yes, I use now PLA 2.0.
What ABS pump dou you have?
